Dell XPS 13 Wireless Card Replacement
  1. Dell XPS 13 Wireless Card Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 Wireless Card Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 Wireless Card Replacement: step 2, image 1 of 2 Dell XPS 13 Wireless Card Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 Wireless Card Replacement: step 3, image 1 of 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 Wireless Card Replacement: step 4, image 1 of 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 Wireless Card Replacement: step 5, image 1 of 1
    • Remove the bottom cover.
  6. Dell XPS 13 Wireless Card Replacement, Battery Disconnection: step 6, image 1 of 2 Dell XPS 13 Wireless Card Replacement, Battery Disconnection: step 6, image 2 of 2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 13 Wireless Card Replacement, Wireless Card: step 7, image 1 of 1
    • Pry the white and black antenna wire connectors straight up from the wireless card to disconnect them.
    • Pry the connectors gently from the bottom of the metal heads.
    • During reassembly, make sure the white cable connects to the socket marked with the white triangle, and that black goes to black.
    • To reconnect each wire, align the connector carefully over its socket and press down firmly.
  8. Dell XPS 13 Wireless Card Replacement: step 8, image 1 of 2 Dell XPS 13 Wireless Card Replacement: step 8, image 2 of 2
    • Remove the 3 mm Phillips #0 screw that secures the Wi-Fi card in place.
    • The Wi-Fi card will pop up at a 45-degree angle once the screw is removed.
  9. Dell XPS 13 Wireless Card Replacement: step 9, image 1 of 1
    • Use your hand to gently remove the Wi-Fi card by pulling it up and away from its base.
Jay
261 Reputation
2 Guides authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
30 Guides authored
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 272
All Time: 15,274
