Introduction
Use this guide to replace the fan in the Dell XPS 13.
Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
Use tweezers to remove the little white connector by pulling it out and away from its socket.
Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
Use your right hand to lift up the larger section of the motherboard, closest to the fan.
Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
