Introduction
If your Dell XPS 13 9350 (also known as Dell XPS 13 Infinity Edge Ultrabook or Dell XPS 13 Skylake) has lost its ability to hold a charge, you most likely have a dead battery, which requires replacement.
A functional battery provides power to your laptop. Eventually, laptop batteries will rapidly drain after going through a repeated amount of charge cycles. If you notice that your charged battery is draining more quickly than usual, consider calibrating your battery to determine an accurate charging capacity. If you continue to notice significant drops in battery percentage, you should replace your battery.
This guide will show you how to remove the battery and the speakers, which are wired to the battery. In Step 7, you will need to use a prying tool to detach the flat connector securing the battery to the device. It’s important to use an ESD-safe prying tool for this step—never use sharp or metal tools near a battery. A punctured battery can potentially cause a fire, especially if it is swollen. If you notice your battery is swollen when you open your laptop, be sure to have a bucket of sand ready and nearby. If the battery ignites, submerge it in a bucket of sand to extinguish the fire.
When you’ve finished the guide, please responsibly dispose of your old battery by following your area’s e-waste laws.
Make sure to power down your device before you begin.
Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
