Dell XPS 13 9350 Battery Replacement
  1. Dell XPS 13 9350 Battery Replacement, Back Cover: step 1, image 1 of 2 Dell XPS 13 9350 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 13 9350 Battery Replacement: step 2, image 1 of 2 Dell XPS 13 9350 Battery Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 13 9350 Battery Replacement: step 3, image 1 of 1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 13 9350 Battery Replacement: step 4, image 1 of 1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 13 9350 Battery Replacement: step 5, image 1 of 1
    • Remove the bottom cover.
  6. Dell XPS 13 9350 Battery Replacement, Battery: step 6, image 1 of 2 Dell XPS 13 9350 Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  7. Dell XPS 13 9350 Battery Replacement: step 7, image 1 of 2 Dell XPS 13 9350 Battery Replacement: step 7, image 2 of 2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • Do not pull up.
  8. Dell XPS 13 9350 Battery Replacement: step 8, image 1 of 1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  9. Dell XPS 13 9350 Battery Replacement: step 9, image 1 of 2 Dell XPS 13 9350 Battery Replacement: step 9, image 2 of 2
    • Use your hands to gently lift up the battery.
    • This image includes the removal of the speakers, which is not necessary, only the tape must be peeled up to allow removing the battery.
Ella Herrmann
1,630 Reputation
3 Guides authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
30 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 20,110
