Dell XPS 12 9Q33 mSATA Card Replacement
  1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the Battery: step 1, image 1 of 1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
  2. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the mSATA card: step 2, image 1 of 1
    • Remove the screw that secures the mSATA card to the system board.
    • Slide and remove the mSATA card out of the mSATA-card connector.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
44,953 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 380
