Dell XPS 12 9250 Battery Replacement
  1. Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: step 1, image 1 of 2 Dell XPS 12 9250 Battery Replacement, Removing the Back Cover: step 1, image 2 of 2
    • Turn the tablet over.
    • Remove the screws that secure the back-cover assembly to the display assembly.
    • Using a plastic scribe, pry up along the edges of the back-cover assembly.
    • Carefully, lift the back-cover assembly and turn it over.
  2. Dell XPS 12 9250 Battery Replacement: step 2, image 1 of 1
    • Remove the screws that secure the battery to the back-cover assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery, along with its cable, off the back-cover assembly.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
44,980 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 2,415
