Dell Vostro V130 LED Cover Replacement
    1. Dell Vostro V130 LED Cover Replacement, Remove the Screws: step 1, image 1 of 1
      • Remove the screws that secure the base cover to the computer.
      Ask FixBot
    2. Dell Vostro V130 LED Cover Replacement, Removing the Base Cover: step 2, image 1 of 1
      • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Ask FixBot
    1. Dell Vostro V130 LED Cover Replacement, Disconnecting the Battery: step 3, image 1 of 1
      • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
      Ask FixBot
    2. Dell Vostro V130 LED Cover Replacement, Remove Battery Screws: step 4, image 1 of 1
      • Remove the screws that secure the battery to the computer.
      Ask FixBot
    3. Dell Vostro V130 LED Cover Replacement, Lift the Battery: step 5, image 1 of 1
      • Lift the battery up and away from the computer.
      Ask FixBot
    1. Dell Vostro V130 LED Cover Replacement, LED Cover: step 6, image 1 of 1
      • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
      Ask FixBot
    2. Dell Vostro V130 LED Cover Replacement, Removing the LED Cover: step 7, image 1 of 1
      • Pull the LED cover toward the keyboard and remove it from the computer.
      Ask FixBot
Finish Line
Johnathan Hammond
46,257 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,277 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 489
