Dell Vostro 3583 SSD/Memory Replacement
    1. Dell Vostro 3583 SSD/Memory Replacement, Prep: step 1, image 1 of 1
      • Power off your Dell Vostro 3583 and remove all accessories.
      Ask FixBot
    2. Dell Vostro 3583 SSD/Memory Replacement, Remove the Cover: step 2, image 1 of 1
      • Use a #1 Phillips screwdriver to remove the ten screws securing the cover.
      • Release the clips along the edges with an opening pick.
      • Remove the cover.
      Ask FixBot
    3. Dell Vostro 3583 SSD/Memory Replacement, Unplug the Battery: step 3, image 1 of 1
      • Gently wiggle the battery connector
      • To disconnect the battery connector, either:
      • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
      • Use your fingers to wiggle the connector out of its slot.
      • It may take a lot of alternating sides before the connector comes out. Be patient, and don't pull on the cables.
      Ask FixBot
    4. Dell Vostro 3583 SSD/Memory Replacement, Sata: step 4, image 1 of 1
      • Here you can find your disk bay. Typically, this laptop comes without a disk installed, however I installed one earlier.
      Ask FixBot
      • Here you can find your Sodimm ddr4 RAM. To remove, follow the video.
      Ask FixBot
    5. Dell Vostro 3583 SSD/Memory Replacement, M.2 NVME SSD: step 6, image 1 of 3 Dell Vostro 3583 SSD/Memory Replacement, M.2 NVME SSD: step 6, image 2 of 3 Dell Vostro 3583 SSD/Memory Replacement, M.2 NVME SSD: step 6, image 3 of 3
      • Here you can find your primary storage. You can upgrade or remove this by unscrewing the two front screws, then removing it. To remove the plate, remove the tiny screw using a PH 000 screwdriver.
      Ask FixBot
    6. Ask FixBot
Lukey T
46 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 56
All Time: 259
