Dell Vostro 3550 Memory Module Replacement
  1. Dell Vostro 3550 Memory Module Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3550 Memory Module Replacement, Sliding the Battery: step 2, image 1 of 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3550 Memory Module Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
  4. Dell Vostro 3550 Memory Module Replacement, Lifting the Access Panel: step 4, image 1 of 1
    • Lift the access panel up at an angle and remove it from the computer.
  5. Dell Vostro 3550 Memory Module Replacement, Memory Module: step 5, image 1 of 1
    • Pry the retention clips away from the memory module until it pops up.
  6. Dell Vostro 3550 Memory Module Replacement, Remove the Memory Module: step 6, image 1 of 1
    • Remove the memory module from its connector on the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
44,953 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,986 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 306
