Dell Vostro 3460 Hard Drive Replacement
  1. Dell Vostro 3460 Hard Drive Replacement, Releasing the Battery: step 1, image 1 of 1
    • Slide the battery latches to release the battery.
  2. Dell Vostro 3460 Hard Drive Replacement, Removing the Battery: step 2, image 1 of 1
    • Lift and remove the battery from the computer.
  3. Dell Vostro 3460 Hard Drive Replacement, Remove the Screws: step 3, image 1 of 1
    • Remove the screw(s) that secures the cover to the computer. Lift the cover upwards.
  4. Dell Vostro 3460 Hard Drive Replacement, Sliding the Cover: step 4, image 1 of 1
    • Slide the cover outwards to release it from the notches on the computer.
  5. Dell Vostro 3460 Hard Drive Replacement, Lifiting the Cover: step 5, image 1 of 1
    • Lift the cover upwards and away from the computer.
  6. Dell Vostro 3460 Hard Drive Replacement, Remove the Screws: step 6, image 1 of 1
    • Remove the screws that secure the hard drive to the computer.
  7. Dell Vostro 3460 Hard Drive Replacement, Disconnecting the Hard-Drive: step 7, image 1 of 1
    • Lift the tab to disconnect the hard-drive cable from the system board. Lift the hard drive to loosen it from the chassis.
  8. Dell Vostro 3460 Hard Drive Replacement, Removing the Hard Drive: step 8, image 1 of 1
    • Slide and remove the hard drive from the computer.
  9. Dell Vostro 3460 Hard Drive Replacement, Removing the Screws: step 9, image 1 of 1
    • Disconnect the hard-drive cable. Remove the screws securing the hard drive to hard-drive bracket. Lift the hard drive from the bracket.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
44,953 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,988 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,672
