Introduction
In this guide, we will be showing you how to remove and replace the Wireless Local Area Network (WLAN) Card.
Slide the left and the right battery release latches to the unlock position.
Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
Release the latch on the system board connector, then disconnect the keyboard cable.
It is also required to loose the screw just beside the latch mentioned in this step.
Pry up the memory door near the screw hole, lift and remove it.
Gently pry the optical drive out of the computer.
Make sure you have loosen the screw beside the keyboard cable latch, mentioned in the comments of Step 8.
Remove the screws that secure the optical drive bracket.
Remove the optical drive bracket from the optical drive module.
Flip the computer around and remove the screws that secures the palm rest.
Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
Release the latch on the system board connector and then disconnect the power button cable.
Release the latch on the system board connector and then disconnect the hot key cable.
Pry up the right side of the palm rest.
There are a couple of latches on the front of the palm rest which should be released before you move on to the sides. I think one of those latches is released in the picture above. The iFixit opening tool was helpful here, and I used some of the iFixit opening picks to stop the corner latches from closing while I worked on others.
Remove the screw that secures the WLAN card.
Pull the WLAN card straight out of its socket and remove it.
You can skip this step, it isn’t strictly necessary.
Cons of removing the WLAN card:
o I found the screw in the last step very stubborn, worried about stripping it.
o Takes time.
Pros of removing the WLAN card:
o Might make disconnecting the system board a little easier later. I had no trouble with the WLAN card in place though.
3 other people completed this guide.
