Dell Vostro 3450 VGA Board Replacement
  1. Dell Vostro 3450 VGA Board Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 VGA Board Replacement, Removing the Battery: step 2, image 1 of 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 VGA Board Replacement, Prying the Keyboard: step 3, image 1 of 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 VGA Board Replacement, Prying the Keyboard retainer: step 4, image 1 of 1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 VGA Board Replacement, Pry up the Keyboard Retainer: step 5, image 1 of 1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 VGA Board Replacement, Prying the Retainer: step 6, image 1 of 1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 VGA Board Replacement, Pull up the Keyboard: step 7, image 1 of 1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 VGA Board Replacement, Release the Latch: step 8, image 1 of 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 VGA Board Replacement, Loosen the Screw: step 9, image 1 of 1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 VGA Board Replacement, Removing the Memory Door: step 10, image 1 of 1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 VGA Board Replacement, Remove the Screw: step 11, image 1 of 1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 VGA Board Replacement, Prying the Drive: step 12, image 1 of 1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 13, image 1 of 1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 VGA Board Replacement, Removing the Optical Drive: step 14, image 1 of 1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 15, image 1 of 1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 16, image 1 of 1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 VGA Board Replacement, Remove the Rubber: step 17, image 1 of 1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 VGA Board Replacement, Remove the Rubber: step 18, image 1 of 1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 19, image 1 of 1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 20, image 1 of 1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 VGA Board Replacement, Release the Latches: step 21, image 1 of 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 VGA Board Replacement, Release the Latch: step 22, image 1 of 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 VGA Board Replacement, Disconnecting the Key Cable: step 23, image 1 of 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 VGA Board Replacement, Prying the Palm Rest: step 24, image 1 of 1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 VGA Board Replacement, Prying the Palm Rest: step 25, image 1 of 1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 VGA Board Replacement, Prying the Sides: step 26, image 1 of 1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 27, image 1 of 1
    • Remove the screws that secure the hinge cover.
  28. Dell Vostro 3450 VGA Board Replacement, Press Down on the Hooks: step 28, image 1 of 1
    • Press down on the hooks highlighted in the image.
  29. Dell Vostro 3450 VGA Board Replacement, Removing the Hinge Cover: step 29, image 1 of 1
    • Flip the computer around and remove the hinge cover from the side.
  30. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 30, image 1 of 1
    • Remove the screws that secure the display hinge.
  31. Dell Vostro 3450 VGA Board Replacement, Loosen the Screw: step 31, image 1 of 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  32. Dell Vostro 3450 VGA Board Replacement, Disconnecting the LVDS Cable: step 32, image 1 of 1
    • Disconnect the LVDS cable from the system board.
  33. Dell Vostro 3450 VGA Board Replacement, Disconnecting the Wireless Cables: step 33, image 1 of 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  34. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 34, image 1 of 1
    • Remove the screws that secure the left hinge.
  35. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: step 35, image 1 of 1
    • Remove the screws that secure the right hinge.
  36. Dell Vostro 3450 VGA Board Replacement, Lifting the Display Assembly: step 36, image 1 of 1
    • Lift the display assembly and remove it from the computer.
  37. Dell Vostro 3450 VGA Board Replacement, Release the Latch: step 37, image 1 of 1
    • Release the latch on the system board and then disconnect the VGA cable.
  38. Dell Vostro 3450 VGA Board Replacement, Remove the Screw: step 38, image 1 of 1
    • Remove the screw that secures the VGA board.
  39. Dell Vostro 3450 VGA Board Replacement, Remove the VGA Board: step 39, image 1 of 1
    • Remove the VGA board from the chassis.
Johnathan Hammond
44,830 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,985 Guides authored
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 6
All Time: 216
