Dell Vostro 3450 Memory Module Replacement
  1. Dell Vostro 3450 Memory Module Replacement, Unlocking the Battery: step 1, image 1 of 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Memory Module Replacement, Removing the Battery: step 2, image 1 of 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Memory Module Replacement, Loosen the Screw: step 3, image 1 of 1
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Memory Module Replacement, Removing the Memory Door: step 4, image 1 of 1
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Memory Module Replacement, Popping up the Memory Module: step 5, image 1 of 1
    • Pry the retention clips away from the memory module until it pops up.
  6. Dell Vostro 3450 Memory Module Replacement, Remove the Memory Module: step 6, image 1 of 1
    • Remove the memory module from its connector on the system board.
Johnathan Hammond
44,953 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 356
