You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
In this guide, we will show you how to remove and replace the Memory Door.
Parts
No parts specified.
  1. Slide the left and the right battery release latches to the unlock position.
    • Slide the left and the right battery release latches to the unlock position.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
  3. Loosen the screw that secures the memory door.
    • Loosen the screw that secures the memory door.
  4. Pry up the memory door near the screw hole, lift and remove it.
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Johnathan Hammond
38,235 Reputation
408 Guides authored
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
38 Members
1,973 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 39
