Asus Transformer Pad Infinity Glass Replacement
    1. Asus Transformer Pad Infinity Glass Replacement, Glass: step 1, image 1 of 3 Asus Transformer Pad Infinity Glass Replacement, Glass: step 1, image 2 of 3 Asus Transformer Pad Infinity Glass Replacement, Glass: step 1, image 3 of 3
      • Disconnect the long silver ribbon connector from the screen.
      • Remove the orange ribbon connector with the two connections.
      Ask FixBot
    2. Asus Transformer Pad Infinity Glass Replacement: step 2, image 1 of 1
      • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
      Ask FixBot
    3. Asus Transformer Pad Infinity Glass Replacement: step 3, image 1 of 1
      • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
      Ask FixBot
    4. Asus Transformer Pad Infinity Glass Replacement: step 4, image 1 of 1
      • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
      • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
      Ask FixBot
    5. Asus Transformer Pad Infinity Glass Replacement: step 5, image 1 of 1
      • Once removed, replace the glass screen back onto the LCD display.
      • The new screen may or may not have new adhesive depending on where you got it. If it doesn’t, make sure you secure it with the screws safely.
      Ask FixBot
Allison Poh
549 Reputation
5 Guides authored
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 31
All Time: 1,160
