Shop the Holiday Gift Guide
Dell Venue Pro Volume Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
51
All Time:
270
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
Use this guide to replace the volume button assembly in the Dell Venue Pro.
The volume button is mounted internally and requires removing the back cover, battery, and motherboard to access it. This guide walks through the necessary steps to safely remove and replace the volume button assembly.
Before beginning, power off the phone and remove the back cover and battery.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Dell Venue Pro Volume Button Replacement, Back Cover: step 1, image 1 of 1
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
      Ask FixBot
    1. Dell Venue Pro Volume Button Replacement, Battery: step 2, image 1 of 2 Dell Venue Pro Volume Button Replacement, Battery: step 2, image 2 of 2
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
      Ask FixBot
    1. Dell Venue Pro Volume Button Replacement, Volume Button: step 3, image 1 of 1
      • Remove the Back Cover
      • Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
      Ask FixBot
    2. Dell Venue Pro Volume Button Replacement: step 4, image 1 of 1
      • Remove the Battery
      • Lift the battery out of its compartment and set it aside.
      Ask FixBot
    3. Dell Venue Pro Volume Button Replacement: step 5, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 5, image 2 of 2
      • Remove the Midframe Screws
      • Use a Phillips #00 screwdriver to remove the 4.57 mm screws securing the midframe to the phone.
      • Keep track of each screw and its original location to ensure correct reassembly.
      • Mixing screw lengths can damage internal components during reassembly.
      Ask FixBot
    4. Dell Venue Pro Volume Button Replacement: step 6, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 6, image 2 of 2
      • Insert a plastic opening tool into the seam between the midframe and phone body.
      • Gently twist the tool to release the clips around the edges.
      • Once all clips have disengaged, pull the midframe upward to remove it completely.
      • If the midframe resists, continue sliding the tool along the seam until every clip releases.
      Ask FixBot
    5. Dell Venue Pro Volume Button Replacement: step 7, image 1 of 1
      • Expose the Motherboard
      • With the midframe removed, the motherboard should now be fully visible.
      • Identify the following components before continuing:
      • SIM card reader near the top of the device
      • Metal shielding covering the center of the motherboard
      • Micro-USB charging port at the bottom
      • Secondary daughterboard connection on the left side
      • Set the midframe aside.
      Ask FixBot
    6. Dell Venue Pro Volume Button Replacement: step 8, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 8, image 2 of 2
      • Disconnect Internal Cables
      • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
      • Disconnect the following cables:
      • Display cable
      • Any remaining flex cables attached to the motherboard
      • Lift connectors straight up—do not pull on the cables.
      Ask FixBot
    7. Dell Venue Pro Volume Button Replacement: step 9, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 9, image 2 of 2
      • Remove the Motherboard Screws
      • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
      • Screws are located near:
      • The bottom right corner (charging port area)
      • The middle left side
      • The top of the motherboard
      • Set all screws aside.
      • Using longer screws in motherboard locations can cause permanent damage.
      Ask FixBot
    8. Dell Venue Pro Volume Button Replacement: step 10, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 10, image 2 of 2
      • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
      • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
      • Once free, remove the motherboard from the device. Set the motherboard aside.
      • Do not flex or twist the motherboard during removal.
      Ask FixBot
    9. Dell Venue Pro Volume Button Replacement: step 11, image 1 of 2 Dell Venue Pro Volume Button Replacement: step 11, image 2 of 2
      • Remove the Volume Button Assembly
      • Locate the volume button assembly along the side of the phone frame.
      • Lift the volume button assembly out of its recess.
      • The button contacts are delicate. Remove the assembly carefully.
      Ask FixBot
    10. Dell Venue Pro Volume Button Replacement: step 12, image 1 of 1
      • Install the New Volume Button Assembly
      • Place the replacement volume button assembly into the phone frame.
      • Ensure it sits flush and aligns correctly with the external button openings.
      Ask FixBot
Author
with
Todjay A Orr
719 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 51
All Time: 270
