Dell Venue 8 Display Replacement
  1. Dell Venue 8 Display Replacement, Rear Case/Midframe: step 1, image 1 of 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Display Replacement: step 2, image 1 of 3 Dell Venue 8 Display Replacement: step 2, image 2 of 3 Dell Venue 8 Display Replacement: step 2, image 3 of 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Display Replacement, Battery: step 3, image 1 of 1
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Dell Venue 8 Display Replacement: step 4, image 1 of 1
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
  5. Dell Venue 8 Display Replacement, Speaker: step 5, image 1 of 1
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  6. Dell Venue 8 Display Replacement: step 6, image 1 of 1
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
  7. Dell Venue 8 Display Replacement, Display: step 7, image 1 of 2 Dell Venue 8 Display Replacement, Display: step 7, image 2 of 2
    • Disconnect the display clip found next to the speaker.
    • Disconnect the Display connection located at the top of the tablet.
  8. Dell Venue 8 Display Replacement: step 8, image 1 of 1
    • Unclip the logic board from the Display.
Mitul
673 Reputation
1 Guide authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 7,139
