Dell Venue 7 Battery Replacement
  1. Dell Venue 7 Battery Replacement, Rear Case: step 1, image 1 of 2 Dell Venue 7 Battery Replacement, Rear Case: step 1, image 2 of 2
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: step 2, image 1 of 1
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: step 3, image 1 of 1
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
chaveza
101 Reputation
1 Guide authored
USF Tampa, Team 11-4, Blackwell Winter 2015 Member of USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Members
10 Guides authored
4 Comments
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Reply
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 7,366
