Dell VRP100 HDMI/USB Cable Replacement
    1. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: step 1, image 3 of 3
      • Remove the black foam padding by peeling away slowly.
      • Remove the front and back padding from the headset by peeling away slowly.
      Ask FixBot
    2. Dell VRP100 HDMI/USB Cable Replacement: step 2, image 1 of 1
      • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Cover panel may need to be pushed in before inserting screws.
      Ask FixBot
    3. Dell VRP100 HDMI/USB Cable Replacement: step 3, image 1 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 3, image 2 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 3, image 3 of 3
      • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
      Ask FixBot
    4. Dell VRP100 HDMI/USB Cable Replacement: step 4, image 1 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 4, image 2 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 4, image 3 of 3
      • Carefully remove the lens and motherboard assembly from the white casing.
      Ask FixBot
    1. Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: step 5, image 1 of 2 Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
      • Peel off the tape using your hands or the blunt nose tweezers.
      Ask FixBot
    2. Dell VRP100 HDMI/USB Cable Replacement: step 6, image 1 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 6, image 2 of 3 Dell VRP100 HDMI/USB Cable Replacement: step 6, image 3 of 3
      • Remove the two 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Hold the HDMI/USB cable and remove from the connection.
      Ask FixBot
5 other people completed this guide.
Marco Salazar
381 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
24 Guides authored
6 Guide Comments
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
jason.d.spiller - Reply Share
Me too, looking for a cable replacement.
Filipi Nascimento Silva - Reply Share
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
Tom Powell - Reply Share
I am also looking for a replacement cable. Could it be soldered on from another cable?
Peter Hindes - Reply Share
Me too for replacement cable specs please
geebee800 - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 39
All Time: 2,080
