Dell VRP100 Cover Replacement
    1. Dell VRP100 Cover Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 Cover Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 Cover Replacement, Cover Panel: step 1, image 3 of 3
      • Remove the black foam padding by peeling away slowly.
      • Remove the front and back padding from the headset by peeling away slowly.
      Ask FixBot
    2. Dell VRP100 Cover Replacement: step 2, image 1 of 1
      • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Cover panel may need to be pushed in before inserting screws.
      Ask FixBot
    3. Dell VRP100 Cover Replacement: step 3, image 1 of 3 Dell VRP100 Cover Replacement: step 3, image 2 of 3 Dell VRP100 Cover Replacement: step 3, image 3 of 3
      • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
      Ask FixBot
    4. Dell VRP100 Cover Replacement: step 4, image 1 of 3 Dell VRP100 Cover Replacement: step 4, image 2 of 3 Dell VRP100 Cover Replacement: step 4, image 3 of 3
      • Carefully remove the lens and motherboard assembly from the white casing.
      Ask FixBot
Marco Salazar
381 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 67
All Time: 1,119
