Dell VRC100-R Touchpad Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
60
All Time:
1,646
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Dell VRC100-R controller does not respond to your touchpad movements, you have come to the right place. To follow this guide, you will need a plastic opening tool and a Phillips #0 screwdriver head. You will not need to do any difficult steps, but open the ZIF connector carefully.
Tools
    1. Dell VRC100-R Touchpad Replacement, Battery: step 1, image 1 of 3 Dell VRC100-R Touchpad Replacement, Battery: step 1, image 2 of 3 Dell VRC100-R Touchpad Replacement, Battery: step 1, image 3 of 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Ask FixBot
    2. Dell VRC100-R Touchpad Replacement: step 2, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 2, image 2 of 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Ask FixBot
    1. Dell VRC100-R Touchpad Replacement, Joystick: step 3, image 1 of 3 Dell VRC100-R Touchpad Replacement, Joystick: step 3, image 2 of 3 Dell VRC100-R Touchpad Replacement, Joystick: step 3, image 3 of 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Ask FixBot
    2. Dell VRC100-R Touchpad Replacement: step 4, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 4, image 2 of 2
      • Grab the joystick and pull away from the controller to remove it.
      Ask FixBot
    1. Dell VRC100-R Touchpad Replacement, Touchpad: step 5, image 1 of 2 Dell VRC100-R Touchpad Replacement, Touchpad: step 5, image 2 of 2
      • Remove one 6mm Phillips #0 screw.
      Ask FixBot
    2. Dell VRC100-R Touchpad Replacement: step 6, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 6, image 2 of 2
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      Ask FixBot
    3. Dell VRC100-R Touchpad Replacement: step 7, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 7, image 2 of 2
      • Turn your controller 90 degrees clockwise and insert a plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      Ask FixBot
    4. Dell VRC100-R Touchpad Replacement: step 8, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 8, image 2 of 2
      Ask FixBot
    5. Dell VRC100-R Touchpad Replacement: step 9, image 1 of 3 Dell VRC100-R Touchpad Replacement: step 9, image 2 of 3 Dell VRC100-R Touchpad Replacement: step 9, image 3 of 3
      • Use the tip of a plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      Ask FixBot
    6. Dell VRC100-R Touchpad Replacement: step 10, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 10, image 2 of 2
      • Place two fingers on the perimeter of the daughterboard and fold it down along the orange cable.
      Ask FixBot
    7. Dell VRC100-R Touchpad Replacement: step 11, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 11, image 2 of 2
      • Remove two black 6mm Phillips #0 screws.
      Ask FixBot
    8. Dell VRC100-R Touchpad Replacement: step 12, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 12, image 2 of 2
      • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
      Ask FixBot
    9. Dell VRC100-R Touchpad Replacement: step 13, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 13, image 2 of 2
      • Remove three 3mm Phillips #0 screws.
      Ask FixBot
    10. Dell VRC100-R Touchpad Replacement: step 14, image 1 of 2 Dell VRC100-R Touchpad Replacement: step 14, image 2 of 2
      • Insert your finger underneath the black plastic "V" and scoop up to remove it.
      Ask FixBot
    11. Dell VRC100-R Touchpad Replacement: step 15, image 1 of 3 Dell VRC100-R Touchpad Replacement: step 15, image 2 of 3 Dell VRC100-R Touchpad Replacement: step 15, image 3 of 3
      • Place your thumb on the outer edge of the touchpad on the other side of the controller.
      • Push toward the center of the circle to get your fingernail underneath the touchpad then scoop away from yourself.
      • You can see the detachable black flaps underneath the touchpad along the perimeter.
      • Turn your controller over and remove the touchpad.
      Ask FixBot
Steven Pineda
1,049 Reputation
3 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
1 Guide Comment
where to get the replacement for touchpad?
Kenneth Alvarez - Reply Share
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 60
All Time: 1,646
