Dell VRC100-R Motherboard Replacement
Views: 2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
10
Past 30 Days:
49
All Time:
2,040
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If many parts of your controller, like the buttons and touchpad, do not function properly, you have found the correct guide. This guide requires a plastic opening tool, spudger, and Phillips #0 screwdriver head. You will not need any expert knowledge, but you will have to take apart most of your controller.
Tools
    1. Dell VRC100-R Motherboard Replacement, Battery: step 1, image 1 of 3 Dell VRC100-R Motherboard Replacement, Battery: step 1, image 2 of 3 Dell VRC100-R Motherboard Replacement, Battery: step 1, image 3 of 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Ask FixBot
    2. Dell VRC100-R Motherboard Replacement: step 2, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 2, image 2 of 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Ask FixBot
    1. Dell VRC100-R Motherboard Replacement, Joystick: step 3, image 1 of 3 Dell VRC100-R Motherboard Replacement, Joystick: step 3, image 2 of 3 Dell VRC100-R Motherboard Replacement, Joystick: step 3, image 3 of 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Ask FixBot
    2. Dell VRC100-R Motherboard Replacement: step 4, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 4, image 2 of 2
      • Grab the joystick and pull away from the controller to remove it.
      Ask FixBot
    1. Dell VRC100-R Motherboard Replacement, Daughterboard: step 5, image 1 of 2 Dell VRC100-R Motherboard Replacement, Daughterboard: step 5, image 2 of 2
      • Remove one 6mm Phillips #0 screw.
      Ask FixBot
    2. Dell VRC100-R Motherboard Replacement: step 6, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 6, image 2 of 2
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      Ask FixBot
    3. Dell VRC100-R Motherboard Replacement: step 7, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 7, image 2 of 2
      • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      Ask FixBot
    4. Dell VRC100-R Motherboard Replacement: step 8, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 8, image 2 of 2
      Ask FixBot
    5. Dell VRC100-R Motherboard Replacement: step 9, image 1 of 3 Dell VRC100-R Motherboard Replacement: step 9, image 2 of 3 Dell VRC100-R Motherboard Replacement: step 9, image 3 of 3
      • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      Ask FixBot
    6. Dell VRC100-R Motherboard Replacement: step 10, image 1 of 3 Dell VRC100-R Motherboard Replacement: step 10, image 2 of 3 Dell VRC100-R Motherboard Replacement: step 10, image 3 of 3
      • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
      • Grab the orange cable and pull away from the socket.
      • To reinstall, insert the orange cable into the connector and close the flap on the white line.
      Ask FixBot
    7. Dell VRC100-R Motherboard Replacement: step 11, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 11, image 2 of 2
      • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
      Ask FixBot
    1. Dell VRC100-R Motherboard Replacement, Motherboard: step 12, image 1 of 2 Dell VRC100-R Motherboard Replacement, Motherboard: step 12, image 2 of 2
      • Remove two black 6mm Phillips #0 screws.
      Ask FixBot
    2. Dell VRC100-R Motherboard Replacement: step 13, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 13, image 2 of 2
      • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
      • The ring may slightly pop as it disconnects from the controller body.
      Ask FixBot
    3. Dell VRC100-R Motherboard Replacement: step 14, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 14, image 2 of 2
      • Grab the black and red wires attached to the motherboard and wiggle the connector out of the socket.
      Ask FixBot
    4. Dell VRC100-R Motherboard Replacement: step 15, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 15, image 2 of 2
      • Remove three 3mm Phillips #0 screws.
      Ask FixBot
    5. Dell VRC100-R Motherboard Replacement: step 16, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 16, image 2 of 2
      • Insert your finger underneath the black plastic "V" and scoop up to remove it.
      Ask FixBot
    6. Dell VRC100-R Motherboard Replacement: step 17, image 1 of 2 Dell VRC100-R Motherboard Replacement: step 17, image 2 of 2
      • Remove two 4mm Phillips #0 screws.
      Ask FixBot
    7. Dell VRC100-R Motherboard Replacement: step 18, image 1 of 1
      • Pinch the orange ribbon cable and pull toward yourself to remove the motherboard.
      Ask FixBot
Steven Pineda
1,049 Reputation
3 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
4 Guide Comments
Thanks, using this as a tear down guide.
Gamerz Crafted - Reply Share
Hi, do anyone know where this motherboard can be purchased?
John Franco - Reply Share
does anybody know where I can buy the ribbon cable, between the two boards. in Step 10
Tim Bury - Reply Share
where can i buy the motherboard?
José Yoctán Leyva Román - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 49
All Time: 2,040
