Dell VRC100-R Joystick Replacement
    1. Dell VRC100-R Joystick Replacement, Joystick: step 1, image 1 of 3 Dell VRC100-R Joystick Replacement, Joystick: step 1, image 2 of 3 Dell VRC100-R Joystick Replacement, Joystick: step 1, image 3 of 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Ask FixBot
    2. Dell VRC100-R Joystick Replacement: step 2, image 1 of 2 Dell VRC100-R Joystick Replacement: step 2, image 2 of 2
      • Grab the joystick and pull away from the controller to remove it.
      Ask FixBot
Kenneth Liu
169 Reputation
2 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 49
All Time: 1,059
