Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: step 1, image 1 of 1
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
  2. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: step 2, image 1 of 2 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: step 2, image 2 of 2
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
  3. Dell Precision T3400 Video Card Replacement, Remove the video card: step 3, image 1 of 1
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
  4. Dell Precision T3400 Video Card Replacement, Install the new video card: step 4, image 1 of 2 Dell Precision T3400 Video Card Replacement, Install the new video card: step 4, image 2 of 2
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.
Josette Cormier
13 Reputation
2 Guides authored
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Members
14 Guides authored
Past 24 Hours: 5
Past 7 Days: 7
Past 30 Days: 22
All Time: 6,567
