Introduction
In this guide, we will be showing you how to remove and replace the Keyboard.
Slide the release latch to unlock the battery cover.
Slide and lift the battery cover to remove it from the computer.
Remove the screws that secure the hard drive to the computer.
Lift the hard-drive latch to the unlock position.
Slide and lift the hard drive from the computer.
Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
Why is this necessary for replacing the keyboard?
Peel the tape to access the cable.
Lift the tab and disconnect the keyboard cables from the system board.
Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
Remove the screws that secure the keyboard to the computer.
Lift the front side and slide the keyboard to remove it away from the computer.
4 other people completed this guide.
One Comment
Einfach und verständlich geschrieben. Habs ohne Probleme geschafft :-)
Nur hab ich mich gefragt: Wozu Schritt 4?! Der ist zum Entfernen der Tastatur gar nicht nötig.
Wer also nur die Tastatur wechseln möchte, kann von 3 gleich zu 5 springen.
Danke für die Anleitung.
Hat mir sehr geholfen.
