Dell Precision 3510 WLAN Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
57
All Time:
240
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will teach you how to disassemble your Dell Precision 3510 Computer to replace the WLAN card. Before you follow this guide, check out the Troubleshooting Pages and confirm that the WLAN card will need to be replaced.
Before you begin the steps to replace the Dell Precision 3510 Computer WLAN card, power the computer off completely and unplug any external devices. You can power off your computer by holding down the power button in the upper right-hand corner of the keyboard for 10-15 seconds.
Tools
    1. Dell Precision 3510 WLAN Card Replacement, Battery: step 1, image 1 of 2 Dell Precision 3510 WLAN Card Replacement, Battery: step 1, image 2 of 2
      • Flip the computer over so that you are looking at the bottom.
      • Use a Phillips #000 screwdriver to remove the eight 6.5 mm screws from the base cover.
      Ask FixBot
    2. Dell Precision 3510 WLAN Card Replacement: step 2, image 1 of 1
      • Use the opening tool to carefully pry the base cover from the computer.
      • Remove the base cover from the laptop.
      Ask FixBot
    3. Dell Precision 3510 WLAN Card Replacement: step 3, image 1 of 2 Dell Precision 3510 WLAN Card Replacement: step 3, image 2 of 2
      • Using a Phillips #000 screwdriver, remove the two 5.5 mm screws from the battery.
      Ask FixBot
    4. Dell Precision 3510 WLAN Card Replacement: step 4, image 1 of 2 Dell Precision 3510 WLAN Card Replacement: step 4, image 2 of 2
      • Gently unplug the cable connected to the top of the battery.
      • Remove the battery from the laptop.
      Ask FixBot
    1. Dell Precision 3510 WLAN Card Replacement, WLAN Card: step 5, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the metal bracket to the WLAN card.
      • Remove the metal bracket from the system board.
      Ask FixBot
    2. Dell Precision 3510 WLAN Card Replacement: step 6, image 1 of 1
      • Carefully detach the two cables that are connected to the WLAN card.
      Ask FixBot
    3. Dell Precision 3510 WLAN Card Replacement: step 7, image 1 of 1
      • Remove the WLAN card from the system board.
      Ask FixBot
Makenna Patrick
643 Reputation
5 Guides authored
Texas Tech, Team 46-3, Johansen Fall 2025 Member of Texas Tech, Team 46-3, Johansen Fall 2025
TTU-JOHANSEN-F25S46G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 57
All Time: 240
