Replacing Dell Optiplex SX280 RAM
  1. Replacing Dell Optiplex SX280 RAM, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Replacing Dell Optiplex SX280 RAM: step 2, image 1 of 2 Replacing Dell Optiplex SX280 RAM: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Replacing Dell Optiplex SX280 RAM: step 3, image 1 of 2 Replacing Dell Optiplex SX280 RAM: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Replacing Dell Optiplex SX280 RAM, RAM: step 4, image 1 of 1
    • The RAM are the two green cards in the corner of the computer.
    • At each end of the card, there are two white clips securing the RAM to the Motherboard.
  5. Replacing Dell Optiplex SX280 RAM: step 5, image 1 of 2 Replacing Dell Optiplex SX280 RAM: step 5, image 2 of 2
    • Push down both white clips with your thumbs until you hear a click.
    • The RAM cards can now be removed.
Wyatt
775 Reputation
6 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 5,487
