Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Remove the Panel Cover to access the components of the device.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
Wyatt
763 Reputation
6 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,734
