Dell Optiplex SX280 Heat Sink Replacement
  1. Dell Optiplex SX280 Heat Sink Replacement, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Heat Sink Replacement: step 2, image 1 of 2 Dell Optiplex SX280 Heat Sink Replacement: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Heat Sink Replacement: step 3, image 1 of 2 Dell Optiplex SX280 Heat Sink Replacement: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: step 4, image 1 of 2 Dell Optiplex SX280 Heat Sink Replacement, Heat Sink: step 4, image 2 of 2
    • Remove the large blue cover from the computer, there are no screws or tabs keeping it in place.
  5. Dell Optiplex SX280 Heat Sink Replacement: step 5, image 1 of 2 Dell Optiplex SX280 Heat Sink Replacement: step 5, image 2 of 2
    • Press down on the release tab above the heat sink.
  6. Dell Optiplex SX280 Heat Sink Replacement: step 6, image 1 of 2 Dell Optiplex SX280 Heat Sink Replacement: step 6, image 2 of 2
    • Pull the heat sink out of the computer while pressing on the release tab.
Tom
841 Reputation
7 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 6,242
