Dell Optiplex GX620 RAM Replacement
  1. Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: step 1, image 1 of 2 Dell Optiplex GX620 RAM Replacement, How to unplug and discharge before repair: step 1, image 2 of 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 RAM Replacement: step 2, image 1 of 2 Dell Optiplex GX620 RAM Replacement: step 2, image 2 of 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 RAM Replacement, Dell Optiplex GX620 Side Panel Disassembly: step 3, image 1 of 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 RAM Replacement, Press the clips: step 4, image 1 of 1
    • Using the tips of your fingers, press out the securing clips on both sides of the memory modules.
  5. Dell Optiplex GX620 RAM Replacement, Remove the memory: step 5, image 1 of 1
    • To remove the memory, pull straight up on the module.
6 other people completed this guide.
Kristina
198 Reputation
7 Guides authored
Pasco Hernando, Team 5-1, Prince Fall 2014 Member of Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Members
15 Guides authored
One Comment
ram price gx620 dill
Shokat Rodnani - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 2,430
