Introduction
In this tutorial we will discuss how to remove and re-install memory into a Dell Optiplex 745 Ultra Small Form Factor. The Dell Optiplex 745 Ultra Small Form Factor encases two DIMM memory slots that can both house a 2GB memory module, allowing a total maximum of 4GB of memory in this machine.
Make sure to shut down the computer! Go to the start menu and click shutdown from the power options first
Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
Lay the computer on its side; you will see a blue knob.
Turn said knob 90 degrees counter clockwise.
While the knob is still turned, slide the panel case forward about 1/2 inch, and then lift the panel off the computer.
Find the power and data cables connected to the hard drive, press down on the metal tab and carefully remove them.
Locate the blue tabs shown on the left and right of the hard disk drive
Squeeze both tabs and slide the hard disk drive towards you, then lift the drive out of the cage.
Press down on the two white tabs on either side of the memory module; the RAM will pop out.
