Installing Dell OptiPlex GX260 Motherboard
  1. Installing Dell OptiPlex GX260 Motherboard, Case: step 1, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard, Case: step 1, image 2 of 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Installing Dell OptiPlex GX260 Motherboard, Main Fan: step 2, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard, Main Fan: step 2, image 2 of 2
    • Disconnect the fan cable from the motherboard.
  3. Installing Dell OptiPlex GX260 Motherboard: step 3, image 1 of 3 Installing Dell OptiPlex GX260 Motherboard: step 3, image 2 of 3 Installing Dell OptiPlex GX260 Motherboard: step 3, image 3 of 3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
  4. Installing Dell OptiPlex GX260 Motherboard, RAM: step 4, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard, RAM: step 4, image 2 of 2
    • Push out on the cream colored tabs on each side of each RAM module until it pops up and out of its slot and remove the RAM.
  5. Installing Dell OptiPlex GX260 Motherboard, Motherboard: step 5, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard, Motherboard: step 5, image 2 of 2
    • Disconnect the ATX power cable to the motherboard.
    • Disconnect the P4 12V(4x2) power cable from the motherboard.
  6. Installing Dell OptiPlex GX260 Motherboard: step 6, image 1 of 3 Installing Dell OptiPlex GX260 Motherboard: step 6, image 2 of 3 Installing Dell OptiPlex GX260 Motherboard: step 6, image 3 of 3
    • Disconnect the front panel ribbon cable by gently pulling it straight up.
    • Disconnect the hard drive ribbon cable by gently pulling the blue tab away from the motherboard.
    • Disconnect the optical drive ribbon cable by gently pulling the orange tab away from the motherboard.
  7. Installing Dell OptiPlex GX260 Motherboard: step 7, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard: step 7, image 2 of 2
    • Disconnect the floppy drive drive ribbon cable by gently pulling the black tab away from the motherboard.
    • Disconnect the optical drive audio cable connector from the motherboard.
    • Disconnect the audio input/output cable from the motherboard.
  8. Installing Dell OptiPlex GX260 Motherboard: step 8, image 1 of 2 Installing Dell OptiPlex GX260 Motherboard: step 8, image 2 of 2
    • Lift the metal tab near the right corner of the motherboard.
    • Pull the green tab toward the front of the PC to release the motherboard.
    • From the rear of the PC, push the ports in while lifting the motherboard up and flipping it away from you.
  9. Installing Dell OptiPlex GX260 Motherboard: step 9, image 1 of 3 Installing Dell OptiPlex GX260 Motherboard: step 9, image 2 of 3 Installing Dell OptiPlex GX260 Motherboard: step 9, image 3 of 3
    • Stand the motherboard up as shown.
    • Insert the flat end of a spudger into the slot in the motherboard mounting plate and press the release tab while pushing the extension plate to the right with your thumbs until it comes off..
  10. Installing Dell OptiPlex GX260 Motherboard: step 10, image 1 of 3 Installing Dell OptiPlex GX260 Motherboard: step 10, image 2 of 3 Installing Dell OptiPlex GX260 Motherboard: step 10, image 3 of 3
    • Remove the screw at the rear of the motherboard.
    • Grasp the heat sink with your left hand and the I/O port panel with your right hand and pull to separate motherboard from the metal base.
    • If you are replacing the motherboard refer to the great iFixit guide for removing the CPU.
Kevin Schapansky
1,457 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
27 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 63
All Time: 38,695
