Dell OptiPlex GX260 Main Fan Replacement
  1. Dell OptiPlex GX260 Main Fan Replacement, Case: step 1, image 1 of 2 Dell OptiPlex GX260 Main Fan Replacement, Case: step 1, image 2 of 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Main Fan Replacement, Main Fan: step 2, image 1 of 2 Dell OptiPlex GX260 Main Fan Replacement, Main Fan: step 2, image 2 of 2
    • Disconnect the fan cable from the motherboard.
  3. Dell OptiPlex GX260 Main Fan Replacement: step 3, image 1 of 3 Dell OptiPlex GX260 Main Fan Replacement: step 3, image 2 of 3 Dell OptiPlex GX260 Main Fan Replacement: step 3, image 3 of 3
    • On the rear of the desktop, push the two circled black buttons straight in with a small pointed object while pulling up on the fan.
    • Once the fan is released, lift it straight up and out of the case.
Kevin Schapansky
1,457 Reputation
9 Guides authored
Cal Poly, Team 4-48, Amido Fall 2010 Member of Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 Members
27 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 7,975
