Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Identify the Hard Drive in the case.
Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
Pinch the two green tabs inwards to release the hard drive and lift it out.
buenos dias como se llama las pieza de color verde que trai el disco duro que trai en los lados
8 other people completed this guide.
One Comment
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
cool de faires des sites comme ca :)
baptiste Prando - Reply
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - Reply
Elvis 1357 - Reply
Elvis 1357 - Reply
