Introduction
Replacing the internal m.2 SSD of a Dell Latitude E7470. You can only choose a 2280 m.2 SSD, the other sizes are not compatible with this PC.
Begin by removing the 8 screws circled in red on the photo opposite with a Philips # 0 screwdriver.
Next, using the iFixit Opening Picks, lift the cover up from the dock connector. Unclip it gently.
After removing the cover, the SSD slot is on the bottom right, right next to the battery.
To remove the SSD, simply remove the single screw that holds it. Lift the SSD to a 30-degree angle and pull it from its slot.
To reassemble your device, follow the instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
8 Comments
It does! It has only one plastic piece (I forgot what the proper term is), not 2.
It’s not working for me with Kingston nvme NV1
If no ram or ssd do ya got to put windows 10 back on I got no recover usb .or a dell recovery usb with 10 or what was original on it .its a e7470
Without RAM you cannot start the computer, it is an essential component.
Without SSD you have no storage so you can't install Windows.
Hyperion -
Is it possible to install two SSD on this Dell Latitude e7470 laptop? I am currently eyeing one and would like to know if to purchase an extra SSD for it.
Thanks in advance.
No extra slot for a extra ssd card. But you can insert High capacity SD card into the Card Slot to give you more disk memory.!
Dumb question maybe - how do you get the cover back on? The front specifically doesn't seem to line up with anything on the main chassis.
It's a good idea to disconnect the Battery before removing any components. This is the pull tab to the left of the NAND SSD and above the battery
Richard Holmes - Reply
