Slide the release latch to unlock the battery before removing it. To remove the base cover, you should remove the Philips head screw on either end of the laptop in the battery compartment, before lifting it up from the screw hole side.
Disconnect the computer hard drive’s cable. [1]
Loosen and remove the screws that lock the hard drive bracket. [2]
Take off the hard drive bracket; this will release the hard drive. [3]
Tighten the screws so that they can lock the computer’s hard drive.
Connect the hard-drive cable to the system board connector.
