Dell Latitude E7440 Keyboard Replacement
  1. Dell Latitude E7440 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Keyboard Replacement: step 2, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 2, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 2, image 3 of 3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide the access door down and remove.
  3. Dell Latitude E7440 Keyboard Replacement: step 3, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 3, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 3, image 3 of 3
    • Unplug bottom cables.
    • Remove two 5mm screws using the Phillips #0 screwdriver.
  4. Dell Latitude E7440 Keyboard Replacement: step 4, image 1 of 1
    • Remove keyboard bezel by using the opening tool to gently pry open the sides.
  5. Dell Latitude E7440 Keyboard Replacement: step 5, image 1 of 2 Dell Latitude E7440 Keyboard Replacement: step 5, image 2 of 2
    • Remove two 2.5mm screws next to the space bar using the Phillips #0 screwdriver.
    • Remove the mouse buttons carefully.
  6. Dell Latitude E7440 Keyboard Replacement: step 6, image 1 of 3 Dell Latitude E7440 Keyboard Replacement: step 6, image 2 of 3 Dell Latitude E7440 Keyboard Replacement: step 6, image 3 of 3
    • Remove the three 3mm screws that are around the perimeter using the Phillips #0 screwdriver.
    • Slightly jerk the keyboard from one side before pulling it one direction.
Sheetal Prasanna
649 Reputation
3 Guides authored
IUPUI, Team S1-G1, Stella Fall 2019 Member of IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 Members
3 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 4,965
