Introduction
If the keyboard of your Dell Latitude E7440 is damaged in any form, use this guide to replace the trackpad.
The keyboard is the main input device used in operating the laptop. A damaged or worn out keyboard or a keyboard with missing keys can be a hindrance while using the laptop.
Before using this guide, clean the keyboard using a soft cloth so that it is free of debris.
Before beginning, make sure to power off your laptop completely and disconnect from any external power source.
Unplug bottom cables.
Remove two 5mm screws using the Phillips #0 screwdriver.
Note that their left hand is holding a thin black plastic covering that first needs to be pulled back.
6 other people completed this guide.
2 Comments
In Step 3, there are four cables to remove, not three (one more to the left which is not highlighted in the picture).
