Dell Latitude E6540 Battery Replacement
  1. Dell Latitude E6540 Battery Replacement, Hibernate your laptop: step 1, image 1 of 2 Dell Latitude E6540 Battery Replacement, Hibernate your laptop: step 1, image 2 of 2
    • Locate the Hibernate option in the Start menu and click it. Once started, let the system finish and replace the battery.
    • Sleep mode: Select Sleep and the computer will be done relatively quickly. However, the power adapter will need to be plugged in.
  2. Dell Latitude E6540 Battery Replacement, Unlock the battery: step 2, image 1 of 2 Dell Latitude E6540 Battery Replacement, Unlock the battery: step 2, image 2 of 2
    • Flip the laptop over, and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Battery Replacement, Remove the old battery: step 3, image 1 of 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: step 3, image 2 of 3 Dell Latitude E6540 Battery Replacement, Remove the old battery: step 3, image 3 of 3
    • Windows 7 systems have a COA under the battery. Windows 8.x systems have a tamper evident label on the service panel (product key in BIOS).
    • Extended runtime batteries will stick out of the system.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Battery Replacement, Install your new battery: step 4, image 1 of 3 Dell Latitude E6540 Battery Replacement, Install your new battery: step 4, image 2 of 3 Dell Latitude E6540 Battery Replacement, Install your new battery: step 4, image 3 of 3
    • This step does not apply yet if used as a prerequisite.
    • Align the battery with the tabs on the back of the laptop. Once done, drop the battery in place and it should lock in. If needed, put light pressure on the battery.
  5. Dell Latitude E6540 Battery Replacement, Plug your laptop in: step 5, image 1 of 1
    • This step does not apply if used as a prerequisite.
    • Turn the computer on and plug the charger in.
Nick
89,227 Reputation
50 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,498 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 8,196
