Introduction
If the fan isn't working properly, the laptop can overheat. This guide will show users how to replace the fan.
Push the tabs on the left and right of the battery out towards the edge of the case.
Push the button in on the CD/DVD drive to eject the drive.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Using the screwdriver, remove four 10mm Phillips #0 spring screws from the fan assembly.
4 other people completed this guide.
One Comment
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
