Dell Latitude E4200 SSD Replacement
  1. Dell Latitude E4200 SSD Replacement, Back Panel: step 1, image 1 of 1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: step 2, image 1 of 3 Dell Latitude E4200 SSD Replacement: step 2, image 2 of 3 Dell Latitude E4200 SSD Replacement: step 2, image 3 of 3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: step 3, image 1 of 1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: step 4, image 1 of 1
    • Unscrew the two 4.10x4.05 mm screws holding the hard drive in place
  5. Dell Latitude E4200 SSD Replacement: step 5, image 1 of 1
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: step 6, image 1 of 1
    • By applying pressure to the sides of the connector, pull the connector apart from the hard drive.
John Shellenberger
490 Reputation
3 Guides authored
Baylor, Team 5-6, Williams Spring 2015 Member of Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 33
All Time: 8,352
