Samsung SPH-A760 Speakers Replacement
  1. Samsung SPH-A760 Speakers Replacement, Battery: step 1, image 1 of 2 Samsung SPH-A760 Speakers Replacement, Battery: step 1, image 2 of 2
    • Push open the latch and remove the battery.
  2. Samsung SPH-A760 Speakers Replacement, Antenna: step 2, image 1 of 2 Samsung SPH-A760 Speakers Replacement, Antenna: step 2, image 2 of 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Samsung SPH-A760 Speakers Replacement, Motherboard: step 3, image 1 of 1
    • Remove the five screws as shown.
  4. Samsung SPH-A760 Speakers Replacement: step 4, image 1 of 1
    • Carefully pry the back plate off.
  5. Samsung SPH-A760 Speakers Replacement: step 5, image 1 of 2 Samsung SPH-A760 Speakers Replacement: step 5, image 2 of 2
    • Carefully detach golden screen connector.
  6. Samsung SPH-A760 Speakers Replacement: step 6, image 1 of 2 Samsung SPH-A760 Speakers Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Samsung SPH-A760 Speakers Replacement: step 7, image 1 of 2 Samsung SPH-A760 Speakers Replacement: step 7, image 2 of 2
    • Place the logic board on a clean tray.
  8. Samsung SPH-A760 Speakers Replacement, Speakers: step 8, image 1 of 2 Samsung SPH-A760 Speakers Replacement, Speakers: step 8, image 2 of 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Samsung SPH-A760 Speakers Replacement: step 9, image 1 of 3 Samsung SPH-A760 Speakers Replacement: step 9, image 2 of 3 Samsung SPH-A760 Speakers Replacement: step 9, image 3 of 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Samsung SPH-A760 Speakers Replacement: step 10, image 1 of 3 Samsung SPH-A760 Speakers Replacement: step 10, image 2 of 3 Samsung SPH-A760 Speakers Replacement: step 10, image 3 of 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
David
25 Reputation
6 Guides authored
Cal Poly, Team 10-43, Garner Spring 2010 Member of Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,073
