Dell Latitude 5400 RAM Replacement
    1. Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 1 of 3 Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 2 of 3 Dell Latitude 5400 RAM Replacement, Back Panel: step 1, image 3 of 3
      • Loosen the eight captive screws that secure the lower case using a Phillips #1 screwdriver.
      • Use a spudger to pry the back panel away from the laptop.
      Ask FixBot
    1. Dell Latitude 5400 RAM Replacement, RAM: step 2, image 1 of 1
      • Place your fingers on the brackets on either side of the RAM stick push them outwards.
      • The RAM stick will pop up at an angle.
      Ask FixBot
    2. Dell Latitude 5400 RAM Replacement: step 3, image 1 of 1
      • Pull the RAM stick straight out of its slot at the angle it is facing.
      Ask FixBot
John Barbato
255 Reputation
2 Guides authored
UMass Dartmouth, Team 3-2, Biswokarma Fall 2025 Member of UMass Dartmouth, Team 3-2, Biswokarma Fall 2025
UMASSD-BISWOKARMA-F25S3G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 72
All Time: 397
