Dell Latitude 3440 RAM Replacement
    1. Dell Latitude 3440 RAM Replacement, Battery: step 1, image 1 of 2 Dell Latitude 3440 RAM Replacement, Battery: step 1, image 2 of 2
      • Slide the battery latches outwards in opposite directions.
      • Remove the battery from the device.
      Ask FixBot
    1. Dell Latitude 3440 RAM Replacement, RAM: step 2, image 1 of 1
      • Remove the SD memory card by pressing on the card to release it from the computer.
      Ask FixBot
    2. Dell Latitude 3440 RAM Replacement: step 3, image 1 of 2 Dell Latitude 3440 RAM Replacement: step 3, image 2 of 2
      • Remove the single 4.7mm screw from the access panel using a Phillips #1 screwdriver.
      • Remove the panel.
      Ask FixBot
    3. Dell Latitude 3440 RAM Replacement: step 4, image 1 of 1
      • Separate the securing clips holding in the RAM.
      Ask FixBot
    4. Dell Latitude 3440 RAM Replacement: step 5, image 1 of 1
      • Remove the RAM from the board by lifting gently and pulling out slightly.
      • Pulling straight up could damage the pins on the RAM module.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 69
All Time: 259
