Dell Latitude 3310 RAM Replacement
    1. Dell Latitude 3310 RAM Replacement, Bottom Cover: step 1, image 1 of 1
      • Remove seven 8.0 mm screws using a Phillips #1 screwdriver.
      • Remove three 5.0 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Dell Latitude 3310 RAM Replacement: step 2, image 1 of 1
      • Using the iFixit opening tool, gently pry between the body of the laptop and the bottom cover. Make your way around the laptop carefully releasing all plastic clips.
      • The screen hinges are an ideal spot to begin prying.
      Ask FixBot
    3. Dell Latitude 3310 RAM Replacement: step 3, image 1 of 1
      • Remove the bottom cover.
      Ask FixBot
    1. Dell Latitude 3310 RAM Replacement, RAM: step 4, image 1 of 2 Dell Latitude 3310 RAM Replacement, RAM: step 4, image 2 of 2
      • Lift the plastic cover up to expose the memory chipset.
      • Carefully pull the clips away from the chip to disengage them.
      Ask FixBot
    2. Dell Latitude 3310 RAM Replacement: step 5, image 1 of 2 Dell Latitude 3310 RAM Replacement: step 5, image 2 of 2
      • After the clips are moved, the RAM will lift up on its own.
      • Remove the RAM.
      Ask FixBot
BrandonWilliams
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 13
Past 30 Days: 39
All Time: 238
