Dell Latitude 10-ST2e Motherboard Replacement
  1. Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: step 1, image 1 of 3 Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: step 1, image 2 of 3 Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Motherboard Replacement: step 2, image 1 of 2 Dell Latitude 10-ST2e Motherboard Replacement: step 2, image 2 of 2
    • Remove the four 4.0mm black screws on the perimeter of the device using a JIS #00 screwdriver
  3. Dell Latitude 10-ST2e Motherboard Replacement: step 3, image 1 of 2 Dell Latitude 10-ST2e Motherboard Replacement: step 3, image 2 of 2
    • Remove the two 4.0mm silver screws using the JIS #00 screwdriver.
  4. Dell Latitude 10-ST2e Motherboard Replacement: step 4, image 1 of 1
    • Disconnect the connection of the front camera clamp by releasing the clamp with tweezers.
    • Pull up on the connection from the motherboard.
    • Avoid damaging the connection.
  5. Dell Latitude 10-ST2e Motherboard Replacement: step 5, image 1 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 5, image 2 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 5, image 3 of 3
    • Using an opening tool, lift upwards on the white clamp, and pull the blue tab out of the connection with tweezers.
  6. Dell Latitude 10-ST2e Motherboard Replacement: step 6, image 1 of 2 Dell Latitude 10-ST2e Motherboard Replacement: step 6, image 2 of 2
    • Using tweezers, disconnect the white and black wires from the bottom of the motherboard.
    • Pull upwards while holding the brass connections. Do not pull on the wires.
  7. Dell Latitude 10-ST2e Motherboard Replacement: step 7, image 1 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 7, image 2 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 7, image 3 of 3
    • Disconnect the two clamps, one orange and one white, using tweezers next to the battery.
  8. Dell Latitude 10-ST2e Motherboard Replacement: step 8, image 1 of 1
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  9. Dell Latitude 10-ST2e Motherboard Replacement: step 9, image 1 of 2 Dell Latitude 10-ST2e Motherboard Replacement: step 9, image 2 of 2
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
  10. Dell Latitude 10-ST2e Motherboard Replacement: step 10, image 1 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 10, image 2 of 3 Dell Latitude 10-ST2e Motherboard Replacement: step 10, image 3 of 3
    • Rotate the motherboard upwards from the tablet using tweezers, but do not remove completely from the device. As you lift, disconnect the black and red wire located underneath the motherboard before removing it completely from the tablet.
Vincent Hoffman
261 Reputation
2 Guides authored
USF Tampa, Team S16-G4, Eyestone Fall 2017 Member of USF Tampa, Team S16-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S16G4
4 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,369
