Dell Latitude 10-ST2e Charging Port Replacement
  1. Dell Latitude 10-ST2e Charging Port Replacement, Charging Port: step 1, image 1 of 3 Dell Latitude 10-ST2e Charging Port Replacement, Charging Port: step 1, image 2 of 3 Dell Latitude 10-ST2e Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • Remove the backplate of the tablet by using the plastic opening tool to lift it up.
  2. Dell Latitude 10-ST2e Charging Port Replacement: step 2, image 1 of 2 Dell Latitude 10-ST2e Charging Port Replacement: step 2, image 2 of 2
    • Using a JIS #00 screwdriver, remove the two 4.0mm screws securing it to the motherboard.
  3. Dell Latitude 10-ST2e Charging Port Replacement: step 3, image 1 of 2 Dell Latitude 10-ST2e Charging Port Replacement: step 3, image 2 of 2
    • Lift up the orange clamp connecting the black DOC B/D cable to the charging board.
  4. Dell Latitude 10-ST2e Charging Port Replacement: step 4, image 1 of 3 Dell Latitude 10-ST2e Charging Port Replacement: step 4, image 2 of 3 Dell Latitude 10-ST2e Charging Port Replacement: step 4, image 3 of 3
    • Place the opening tool underneath the charging board, lift up, and slide it out the charging port, along with its board.
Khawja
258 Reputation
2 Guides authored
USF Tampa, Team S16-G4, Eyestone Fall 2017 Member of USF Tampa, Team S16-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S16G4
4 Members
13 Guides authored
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 14
All Time: 860
