Dell Latitude 10-ST2e Battery Replacement
  1. Dell Latitude 10-ST2e Battery Replacement, Battery: step 1, image 1 of 3 Dell Latitude 10-ST2e Battery Replacement, Battery: step 1, image 2 of 3 Dell Latitude 10-ST2e Battery Replacement, Battery: step 1, image 3 of 3
    • Place tablet face-down on flat surface.
    • Using the plastic opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Battery Replacement: step 2, image 1 of 2 Dell Latitude 10-ST2e Battery Replacement: step 2, image 2 of 2
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  3. Dell Latitude 10-ST2e Battery Replacement: step 3, image 1 of 2 Dell Latitude 10-ST2e Battery Replacement: step 3, image 2 of 2
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
Vincent Hoffman
261 Reputation
2 Guides authored
USF Tampa, Team S16-G4, Eyestone Fall 2017 Member of USF Tampa, Team S16-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S16G4
4 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,405
