Introduction
If your laptop overheat, you must open it and clean the Heat-Sink system. This video will show you how to do this.
Video Overview
Switch-off the laptop and remove the battery.
To remove the keyboard lift it from one side by using cutter. Now open 4x locking clips at the upper side on the keyboard.
Open the keyboard flex cable connector and remove the KB.
Open the RAM memory cover.
The DVD drive is held by one screw. After unscrewing, you can remove the drive.
12x screws M 2,5x5,0
4x screws M 2,5x5,0
Power switch cable connector
Mouse pad cable connector
Hot keys cable connector
After removing all the screws and opening all the connectors, you can remove the upper case.
Eject the Card Reader Blanking Plate.
Disconnect the LCD display flex cable.
Disconnect the WiFi and Bluetooth coaxial cables.
The LCD display hings are held by 4x M 2,5x5.0 screws.
Now you can remove the LCD display module.
Unscrew 5x M2.5x5.0 screws.
Disconnect the Loudspeakers cable connector.
Remove the Daughter Bluetooth board.
Start removing the mother board by lifting from the right side (near to the DVD drive connector).
Be careful, there are connectors between mother board and another two additional small boards (charging port board and USB connectors, WiFi card slot board).
Now put a new thermal paste / compose to the CPU. Cover all the surface of the CPU crystal with the thermo-compose.
