Dell Inspiron Mini 1018 WiFi Adapter Replacement
  1. Dell Inspiron Mini 1018 WiFi Adapter Replacement, Battery: step 1, image 1 of 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 1018 WiFi Adapter Replacement: step 2, image 1 of 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 1018 WiFi Adapter Replacement, WiFi Adapter: step 3, image 1 of 2 Dell Inspiron Mini 1018 WiFi Adapter Replacement, WiFi Adapter: step 3, image 2 of 2
    • On the bottom of the laptop locate the removable panel and screw holding it to the body. Loosen the screw and take the cover off.
  4. Dell Inspiron Mini 1018 WiFi Adapter Replacement: step 4, image 1 of 2 Dell Inspiron Mini 1018 WiFi Adapter Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the black and white antenna cable from the wifi adapter by pinching the gold contacts with the tips of your finger, or you can use tweezers, and pull them straight away from the adapter.
    • Unscrew the single 5mm Phillips 0 screw on the top right of the adapter. The adapter should start to angle away from the body of the computer. Once the screw is off completely, pull the adapter out of the data slot.
Bariso Shuba
270 Reputation
3 Guides authored
UW Tacoma, Team 1-4, Rose Fall 2016 Member of UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 988
